mRodiek »
https://forums.nicoclub.com/mrodiek-u91521.html
Sun Feb 08, 2009 9:29 pm
Minor update for yall, got the turbo lines ON and the exhaust manifold hooked up to the turbo .
Just sittin there lookin fastcompressor inlet-green stuff? idkNow this bugged me a little bit, if you look just behind the small rounded triangle there are chips missing out of itOne side of the triangle isnt chippedThe nuts to the wastgateWater Outlet torqued in using Teflon tapeLine attatchedOil ReurnOil Inlet i think, I got confused between oil/water inlet, so I hope I put em on rightWater InletExhaust Manifold + Studs+ Gasket [only fits straight one way] Copper nuts, I could only torque ONE down..Almost done, gotta go back and tighten/check some things
Couple of questions:1) How am I supposed to torque down the rest of the copper nuts on the turbo->exhaust mani? I could barely get em with a wrench!2) Should I just tighten the lines to the attatchment that goes into the turbo down hand tight or with a wrench? How tight?3) Some please tell me I put the oil/water inlet lines in the right places lol
