tEknoS13 wrote:hey dude do you mind if I put up some pics about the shapftplay? I also want to ask WC for something.
go ahead dude im curious to see it myself!
Bumnah wrote:Replace any rubber hose you can touch.Replace any gasket you remove.Replace flywheel and clutch (delay installation of the motor until you can afford the parts if need be).
When installing new exhaust manifold use lock washers.Don't use that crappy copper mr. gasket gasket for the exhaust manifold. Use an exhaust manifold gasket from a 2001 sentra with an sr20de.Replace water pumpReplace thermostatReplace rear main seal
If you're even half way interested in replacing the turbo elbow do it now. Do it with the motor in the car is a pain.
Not sure what all you've done as I only looked at the pictures. Good luck with it.
THAT IS ONE F'n CLEAN MOTOR!
-im trying to go ahead and replace most gaskets and hoses -i am puting off installing it until i do have the clutch/flywheel-wont be using spray a gasket-never used it before lol-tstat being replaced-water pump & rear main seal..we'll see because im way over budget as is lol-the elbow i plan on getting if i upgrade the turbo, as well as a test pipe where my A/R gauge will be hooked up
thanks for the interest
White Comet wrote:i bought the flywheel used and the clutch on ebay. i forget the seller, but it was this same kithttp://cgi.ebay.com/ebaymotors...A1318brand new for much less. i'll try and find out the seller and get back to you
gracias amigo!!
