drift with no front sway
Nissan dominates the drift scene - Always has, always will.
nismostate
Car: all sorts of motorsports
well, i broke my end link when i was changing my control arm. i can't get a new one yet so i tested my car without it. seems ok. i have the setting set with the front stiffer than the rear. holding the drift was easy but seems like it was harder to initiate a drift at higher speed.
sixxdeuce
Car: 93 rx7, G35coupe 6mt
fix your car man. If you want a stiffer rear buy a hicas rear bar and stay with a stock front. Or get some aftermarket bars.
Anand
Car: 95 Nissan 240SX
I wouldn't recomend drifting with no front sway bar...
its too unpredictable that way
nismostate
well there is an event coming up and i don't think i can get a end link by then. i've been driving around lately and it seems fine. i think i can drift fine with no sways in the front.
my set up
sr with smic and turbo back exhaust. k sport 7 F 5 Rctune rear control armtein tie rodjic F and R strut bar. moog F ball jointssoon to put onadj tension rod and nismo power brace.
Modified by nismostate at 2:09 AM 5/31/2005
gogg
Car: 89 240sx silver hatch (burrito)
Yay for turn-in like a hovercraft!
sil beer s13
Car: Kumori SPL S14
nismostate wrote:well there is an event coming up and i don't think i can get a end link by then. i've been driving around lately and it seems fine. i think i can drift fine with no sways in the front.
my set up
Wow i did not see any type of LSD in that at all.
SO how is it that you "drift"?
CaoBoY
Car: 240sx
you can drift with no lsd, just not as well, and more likely to initiate it with the e-brake.
sil beer s13
Car: Kumori SPL S14
CaoBoY wrote:you can drift with no lsd, just not as well, and more likely to initiate it with the e-brake.
I know that i was just being a smart ***.
nismostate
oops. i have a j30 vlsd. i believe i can adjust the suspension to have more understeer and having the FRONT sways dislocated it'll equal out with enducing more oversteer. doesn't matter, i'll find out on drift day. i've already played around in a parking lot with messed up camber and damp, drifted fine.
CaoBoY
Car: 240sx
all good! jes kinda wanted to defend people who started out drifting with an open diff.
Return to “Nissan Drift Forum”
