raging panda »
https://forums.nicoclub.com/raging-panda-u4045.html
Wed Jun 15, 2005 6:32 pm
welded diff is Perfectly safe as long as you arent a bad driver, it comes down to the driver, not the diff. No different than a 2 way. VLSD sucks when it gets hot, yea, modest drifting for like 5 minutes, then you are open diff. you got me on the part where if the weld breaks, you have to be towed, but if you get someone who is a good welder, and you dont use huge tires, your welds should hold up fine. I keep a spare diff at home just in case. Some guys have been running a year + on welded, so it depends on your welder.
i guess i should add a disclamer that if you dont have any experience with sliding around, or you are a beginner driver, or its your first rwd, then dont weld your rear end. Get used to the car as it is before you go changing stuff on a car and style of driving you arent accustomed too. Otherwise, the welded is fine for drifting, and driving on the daily grind, but it is your own risk if you break an weld or axle.
