iamadirtdude wrote:im in somewhat the same position...... my question to you guys and i think this will help him as well.... I'm looking into some coilovers for under $1k and wheels that i can run low pros and wider tires on since the stock wheels are narly. anyway as far as spring rates and dampening what should i look for? and running a stock body s13 whats the widest wheel i'd want to go with? i'd like to use 17's or 18's and what back space?
just about everything your asking for is subjective depending on you..? but i will try my best to answer all of your questions.
Spring rates and dampening:on my AE86 i decided to go with 6kg front 5.5kg rear when i first started drifting, but what i got on my 240sx and what most people seem to go with 8kg Front and 6kg Rear, unless you wanna be real hardcore and go with 12kg Front and 10kg Rear, which in my opinion is really unnecessary unless its solely for a drift car cause it sucks to have to ride them for a daily.
Coilovers:Coilovers under 1k most people seem to go with megan streets, because they usually run around $900, which come with the spring rates 8kg Front and 6kg Rear, and Pillow ball upper mounts. They are also 32-way adjustable, which honestly you probably wont need all those.
In my opinion I would say save another paycheck and you are now open to a larger option of coilovers.
Stance(Very Good Reviews and not too expensive)
SPL KTS(Similar to Stance, Inverted monoshock design which is suppose to preform better then upright design, these are what I run)
Megan Street/Track(Perform well for the price)
Cusco(Good quality, but I dont believe they are height adjustable)
D2(Made in Taiwan.. But some people find them ok)
KSport(Cheap but still good quality)
Silk Road(Expensive but excellent)
JIC(Depends on the coilover but overall pretty good)
Tein(HE's have had good reviews, Basic Damper Kit is junk)
Tanabe(Depending which ones, a few problems but others prefer them)
Hopefully that gives you a few options you could look into.
As for tire width and what not im sure there is a right up somewhere on this forum. But from what I seen people can 9" in the rear with a little fender rolling and for the rims thats up to your own personal taste but honestly i would say 16" or 17" max any bigger just seems pointless for drifting, just get a good offset wheel and some cheap tires since the point is to burn them off. Hope that answered your questions.-JR
