F4ucc »
https://forums.nicoclub.com/f4ucc-u3905.html
Tue Oct 28, 2003 8:51 am
Well, yes.
It takes more than just setting up right for drift, In the game of drifting, it all comes to driver.As for tires pressure, I use between 37-40 in front and about 40 in back. Keep in mind, if you are a rookie, you might feel it's lot easier to start to loose your rear end with higher tire pressure in back and lower tire pressue in front, however sometimes, you want your front tires to push a little bit so you could mantain bigger angle and avoid spining out. Anyway, be safe. it really takes a while just to be able to learn a thing or two.
Remember to use same tires all around as you get better.
later
