(Yoshi) »
https://forums.nicoclub.com/yoshi-u23191.html
Sun Oct 01, 2006 6:40 am
Is it stock? Open diff?
If so. I have some advice.
You have to be going faster if its open diff. Would be better to do it at a track. To start the drift do a feint, so you steer to the outside of the turn and steer back in. As you steer back in pull the hand break. Some things to remember about pulling the hand break: Push in the clutch, push in the little button on the hand break, and put the hand break back down. After you pull the hand break while steering in get on the gas pop the clutch. As the car starts to slide let go of the steering wheel and it should go straight into counter steer. If you let go and it doesn't counter-steer, give the steering wheel a flick to get it started. Then from there if you feel yourself straightening out, steer in to the turn more. STAY ON THE GAS. As you exit the turn slowly let the wheel straighten so you don't flick back the other way.
All it takes is practice, it can be done w/ an open diff. Trust me lol. Once you get it once tho, you can do it again and again.
Good luck
