poshatch »
https://forums.nicoclub.com/poshatch-u145419.html
Wed Jun 16, 2010 10:37 am
usually alignment specs are about preference/test/and experimentation but ill give you a basic set up and my set up (which is slightly different than the model)
basic:
(front)
camber: -2* - -3* (usually where stock coilovers camber adjustment maxes out, maxing out the top plates gives you more SAI and faster "self steer" and the added camber helps with traction)
caster: (preference oem is i think 4-6, commonly around 6-7 some people higher, ill tell you what it does to help you understand where you might want it...it help adjusts straight line tracking so a lower caster will make the steering feel lighter and a higher caster will make it feel heavier but in my experience alot more responsive the faster you go)
toe: (oem spec i think its in a slight bit like 30')
(rear)
camber: -2* - 3.5* (the more you have the less grip your going to have but run whatever fits the wheels under your fender haha)
caster/thrust angle: (dont bother with this but if you have traction rods, on a slammed car extend them 10-15mm over stock or keep stock length)
toe: (oem spec i think its 0*)
me:
(front)
camber: -5.5*
caster: 8.0*
toe: OEM SPEC
(rear)
camber: -2.5*
thrust: (lengthened traction rod roughly 10mm)
toe: (will be running slight toe in, between 30' - 60', currently OEM SPEC)
hope this helps
