nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Thu Apr 22, 2004 11:44 am
I dunno, it bugs me that I don't know when everything is warmed up. It won't be quite as stock then either (exhaust, headers, cams, probably pullies). I doubt I'll get all 6, probably just the 3, and I figure those two temp things are really what's going to show me when my car is warm, the A/F is more for kicks than anything else. Grille would go ahead of gauges for sure, that list isn't quite in order, lemme put it by priority:1. Pedals2. Grille3. VC paint4. Interior re-covering, if it weren't so expensive... GAR!5. GaugesA good suggestion might jump ahead of any of those.I can probably do the top 3 all right now for pretty cheap, if I can find a grille, which seems to be damn near impossible. Anyone know if I could just cut the plastic where the Nissan badge used to be? Also, could someone possibly p-chop the Nissan off the grille if they're bored?
Probably going to drop either BBS RDs or Enkei RS5s in 17X7 form next summer (2005) with some nice sticky rubber.
Basically, I plan to do something small right now just to keep myself from going insane and to have something to work on. Next I can't decide what I want to do first, meaning if I want to wait a couple more weeks into the summer (say, late June, early July) and do suspension, and if so H&R Sports w/ Koni Yellows or JIC FLT A-1s (the latter being ~$300 more expensive) OR do an exhaust from our good buddy at BRM, AZHitman, in early June. Then headers and probably a rear sway, front too if I've got cash. If I still have cash available then I'll get the pullies, unless I have lots, in which case I'll go ahead and do cams. Next summer is rims/tires, cams, pullies, Stillen front lip and rear diffuser and some slightly larger side skirts to even it out (I want them to look like the stock ones pretty much though, rather than that crazy stuff with folds and angles and crap). Then the car is done, as it will be my daily driver and occasional weekend warrior until I get a project =D, which will probably be a Miata (mm... rotary Miata) or something else more fun.
edit: Oh, I would go turbo, but that'd be pretty well pointless on a front driver that I'd rather keep pretty reliable and not blow $3k on turbo. Front wheels just spin, they're too easy to break loose as is. I do plan on getting a Spec V Helical LSD in order to help with that a little, the VLSD is okay for now.
