dremel port and polish
wilfonzo
Car: s14
has any one done a P&P with a dremel, or can someone offer up any advice, i have an extra head collecting dust, so i was thinking about rebuilding it and replacing the head i have on there now which i think has leaky valve seals
corn322
Car: 1993 240sx
Take your time. If you remove too much metal from the wrong spot, it will do a lot more harm than good. I'd concentrate on making everything smooth.
wilfonzo
Car: s14
makes sense
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
in my experience a real porting tool is the best investment here! I once used a dremel tool and it just bounced all around. with a real porting tool you can lower the speed without sacrificing torque because it uses a better reostat than dremel. I love my porting tool and it makes things so much easier, plus the bits are larger and remove larger amounts of material faster.
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
I imagine you're talking about carbide bits on a die grinder of some sort correct? At least that's what I used. I tried the whole dremel thing and it just took uneven gouges out of my head ports. The die grinder you can slow down a lot and really smooth things out. I'd reccomend getting a die grinder (air or electric), some carbide bits and some grinding stones to finish smoothing things out, you'll be set with that.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
pnuematic, and compressor is the only way to go.Although dremel now offers a multi speed cordless which also does a pretty good job..
