Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Jul 23, 2004 4:09 pm
Brought up in a conversation between myself and alan, here is mine
FRONT:-Apex-i N-1 JGTC spec coilover(8/6, bound/rebound adjustable, incoudes upper mounts, etc)-T/C rods made of Chromoly(for strength) heim joints, of course.-Adjustable front LCA made of chromoly or alluminum w/ heim joint and spherical ball joints-Kazama heim joint tie rod ends/stronger S14/Tein inner TR-T/C bracket Brace(tanabe or NISMO)-Front STB(cusco OLC apex-i C/f or other light weight/strong mfr)-Cusco/ST Sway bar w/poly end links or adjustable units
REAR:-Apex-I coilovers(See above)-R STB(cusco c/f)-Chromoly/alluminum heim joint adjustable Toe Rod, UCA, and Traction Rod.-Alluminum subframe bushings-Heim joint spindle bushings (where the rods attach)-Cusco/ST sway bar w/poly end links/bushings or adjustable unit
Post your dream setup if you like please dont include chassis bracing(roll cage, fender braces, etc) or brakes/differential stuff....keep it suspension related(no wheels either)
w00t.note: this list may change quickly as I remember things I'd like in the next few days...-chet
