PhysicZ32 »
https://forums.nicoclub.com/physicz32-u217107.html
Sun Apr 07, 2013 9:28 am
So I ended up taking my 90 2+2 TT to a performance shop, they did the compression test and said there is nothing even close to a problem. He did say that I was having a piston misfire and that it was most likely electrical. I spoke to him about ten last night and he said he already had it running much smoother. Kinda make me wonder if that other place just f*** up, or were straight up trying to f*** me out of several grand. So Now it looks like I will have my issue taken care of within a day or two, and only for a couple hundred. I noticed that my Z has an upgraded ECU, it has 370 circled. So two more questions, I heard you can flash the ECU your self, or have someone like these performance guys do it and it can make a major difference it several aspects, Any thoughts? Even Possible? I ended up learning that my Z has about $6000-$7000 in upgrades, Engine, Clutch, ECU, Intercoolers, But They showed me I am still using the Stock air intake, I've been reading about Pop Chargers? Would that be the next logical step in stepping my Z's horses up? Or is there something you thing I could better spend around $1000? Interiors almost perfect, very very little body damage. I hooked it up with quite the system already, Ended up getting two Ten inch Audiobahn 1000Watt Woofers and upgraded the previous 6 1/12 and what ever the hell size that was supposed to be in the back. 1000 watt RMS JL Audio amp powering it all. So, Pop Chargers? ECU Flashing? I do think I am going to take about $300 or so and replace every electrical cable I can see that even looks a little suspicious. Found complete replacements online for $280-$350 depending on how good of shape the electrical crap is. eBay seems to have just about the same s*** as everyone else, but a little cheaper, Anyone have any bad experiences through eBay, concerning Z32 parts? As for the pop charger which one do I want? I also think I should replace all my fuel ijectors with the after market ones, this shop said they could do it for pretty cheap, also would upgrading PIVOT Turbo Timer do anything? Also, Im sure this shop will have it figured out, but could the Mass flow air sensor cause the engine to run to rich or too lean??? Guess , I went off there a little, just excited that its not messed up valves or piston rings. More than a couple questions, thanks guys!!!!
