Hello 05 fx35 awd. Got the p1273 ok can find vac leaks,redid the plenum gasket ,throttle body,valve covers, took out vatch cans,changed all o2 and AFR
Changed fuel damper. At first it was only p1273 b1s1 lean. So i switched AFR sensors from side to other. I did that an started getting p1283 b2s1 lean.so i figured sensor bad . Got a new one installed did the peddal relearn,throttle,euc,an stored.valuse relearn . Still have p1283 .any advice?
