Darius wrote:So currently, when the key is turned to START, there is not even a click and the engine doesn't turn at all? Correct?
The engine does not, nope, not even a click.
Quote »And when you turn the key to ON, does the dash light up correctly or is it still irregular since you've replaced the battery? [/quote]Yes, it lights up correctly all of the accessories work and all. It's only irrecgular when I try to take the key out the dash lights sometime flicker like a relay isn't cutting over all the way, but you don't here the relay.
Quote »It sounds like it may be a starter issue where it is not getting a signal to ground the solenoid valve and engage the flywheel. [/quote]I don't think it's the starter because of the voltage test I did on the wire that goes to it. It doesn't recieve anything from the IPDM and the IPDM recieves the signal from the ECU. It might be the ecu since the IPDM is brand new. I don't know...
