Q451990 wrote:Well, Q2's climate control display has been intermittant for a few weeks now, but it's finally gotten to the point that it was more dead than alive. Then this afternoon the a/c stopped working, although the fan and vent positions worked fine. I haven't heard of this much before - has anyone else's failed where the controller wouldn't turn the compressor on??Heath
Hey Heath,
Mine will do the intermittent non functioning as well. I posted a while back that it seemed to be when the ambient temp sensor was reading goofy (falsely reading -50deg, etc) it would not turn on the compressor.
I've also found that the unit is less likely to work when the entire system is turned off, then turned on. If I leave it on vent all the time & turn the a/c on when needed, it cranks right up without the gremlins, so I leave it on vent all the time. If for some reason I have to turn it off, when I turn the vent back on and drive a couple of cycles (drive, shut down, return later) it will be ok.
