NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Mon Nov 10, 2014 2:53 pm
Sounds like a MAF issue, O2 issue, fueling issue, or vacuum leak. As soon as the car goes to closed loop (starts reading MAF & O2s) you start having issues. Read codes, check for vac leaks, ohm out injectors, checkMAF outputs, check TPS. All of these procedures can be found in the FSM. In the future if you want to avoid futile waste of time randomly chasing issues, review the FSM first, everything you need is in there.
