drain plug washer question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
BlackMetal
Car: 2009 Super Black Altima Coupe 2.5L 6spd
Hello guys, During the week I came up on my oil drain interval, and changed the oil and filter after work, I did not have a new drain plug washer, I reused the original washer as this was the first oil change and did tighten the drain plug to 25ftlbs. is this an issue? I will be getting some new drain plug washers as soon as I can get to the dealer...
I`m javing a hard time finding these online, the ones I found were so far away that driving to the dealer is much cheaper than the shipping costs, but at the expense of paying dealer prices... I`m not being cheap, just looking for convenience and ordering online... thanks for your help...BluVersa...
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
Nope will be fine... I have been known to re-use then 3 or so times.
I have picked mine(washers) up when I was ordering filters.
BlackMetal
steed, I just got back from the local dealer and bought 8 washers... that`s what they had in an open bag... what type of filters do you use and where do you get them?
I used the hastings LF113... I think they are a better quality than the OEM.
I know there are many opinions on filters and oil and synths etc... the best thing is what works best for the situation and if the driving habits warrant longer drain intervals...
I`m on the bubble about switching to Amsoil in the cars, I never keep the oil in longer than 7500-10K with Ea filters. but the other car is an Altima stick and could prolly benefit from the synth`s, well see... Thanks...
steed77
I get OEM filters.... I get anything but Fram.
I would NEVER trust ANY oil for more than 5K miles. just because the Versa take 3.5qt.. it's sooo little oil, just change it.
BlackMetal
that is
steed77 wrote:I get OEM filters.... I get anything but Fram.
That is an excellent point!
our 09 took 4 qts with filter change...
McLeod1981
Car: Brilliant Silver 2009 Versa 1.8S w/ power-package, cruise control
copper crush washer 18-20 lbs in or hand tight (crush washer crushed) newer versa's have a higher oil capacity compared to earlier 06-07 units factory filters are fine
but i personally recommend wix filters myself and recommend sticking with 5w30 oil, also highly recommend oil changes any where between 3750-7500 miles depending on weather you use conventianal oil (3750) synthetic blend (5000) or full synthetic (7500)
engine air filter when dirty replace or clean depending on weather it is a reusable unit or not. cabin micro-filter every 15000 miles or 1 year which ever comes first more often in dusty conditions/ high pollen season's .
that is just my 2 cents worth.....wait with the current economy make that 6 cents.
conversation
Car: Versa 1.8 S HB
I've never heard of replacing the washer when changing oil. I've never replaced it, and never had a problem. Oh well.
NODES
Car: 2007 Nissan Versa SL (Blue)
conversation wrote:I've never heard of replacing the washer when changing oil. I've never replaced it, and never had a problem. Oh well.
first and only time I did not replace it and the sucker leaked like crazy, it is a few pennies so I replace it every oil change now
Return to “Versa Technical Discussions”
