96'er »
https://forums.nicoclub.com/96-er-u74820.html
Thu Oct 04, 2007 4:19 am
Janice:
I found the two drains in the front, you need to either look up through the sunroof or open the door and stand on the rocker panel. Look in the front corners using a flash light and you should see a hole approximately 3/8" in diameter. If you don't see the hole, use a piece of straight wire and pull the debris away from the hole, don't poke it in or you may jam up the drain tube.
I don't know if there is any other drain holes, if so, would someone please advise us.
Thanks.
