Drain gas tank
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
footy3
Car: '14 Infiniti QX80
I have a 2019 QX60, put 5 gallons from a can in last night, today the car died 2 blocks form my house, won't start at all, just turn over. Thinking the gas was bad or full of water. Does anyone know the easiest way to drain the tank on this model?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The fuel pump service cover is under the lefthand second row seat, not very difficult to access. However, the pump is complicated to hotwire because of the variable pump control. Your best bet is probably to remove the pump and start a siphon.
footy3
Ok, thanks for the prompt reply, appreciate it.
VStar650CL
Technical Expert
:dblthumb:
Return to “Infiniti JX35 / QX60 Forum”
