Nope if your going to replace the fuel pump or use the modified Fuel Pump Control Unit fro m 3Q Jay then just run the gas tank as low as possible. Then simply remove the gas tank, Thats what a "mechanic" did to my 1991 Q45.
When taking out the fuel tank leave the sending unit on there as that will prevent any fuel from spilling out. When your don there should be only a couple of gallons left of fuel plus 10-15 LBS of the tank.
That way you don't risk spilling any fuel.
I was kidding about before as I only got 2 hours of sleep.
