So here's some pics of the fun...
First off, I figured I'd weigh the Bertha - 4300lbs with 55% Front 45% Rear Weight Distribution with an empty tank and me in it. I'm a rather large guy at 300lbs and just after I weighed the car I added 16 gal of fuel, so total race weight, 4400lbs. 4100lbs without me in it.
Interesting Data log here. This launch was a full, 100% foot to the floor no lift launch, and you can see the throttle map does some weird funky stuff up till 32mph. Also the throttle never hits 100%. Most I get is 89% open. Would be nice to tune this out and open them blades 100%.
Next is my run. You can see the time is 13.56 sec @ 105mph 1/4 mi with a 2.2 60ft time (this is lousy!) A good 60ft time for a big girl like this is around 1.8 - 1.7sec. Thats a huge amount on the back end of the track.
Also you can see the Dragy tracks the Elevation change on the run too to make sure you aren't on a down-slope as an advantage. if anything, mine is a slight up-slope.
It also tracks the Density Altitude, otherwise known as DA. DA is the density of the air. The lower the Density Altitude the more HP you'll make. Mine was about 3800ft DA. See Motor Trends article on Testing accelleration and correcting for DA here https://www.motortrend.com/news/motor-trend-testing/
BTW, the 0-60mph time was 5.1sec
My DA is below...DA correction = 12.9sec @ 110mph 1/4 mi
And here it is, the Dragy...Little Box, Big Power. I'll be using this little guy along with Dyno Numbers to track the Horsepower per Mod.
