turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Sat May 12, 2007 5:17 am
you might of spun a rod bearing and send the rod through the block, highly unlikely you sent the pisiotn.
detanation may cause this , to much timing under boost? to hi cyld. temp and pressure. ect.. many causes more info on what happened?
