Drag wheels setup help Hoosier with Summit
DSM4LIFE-AWD
Car: 1995 Eagle Talon TSi AWD
Hi guys, me and my friend want to put some racing wheels and drag tires on his 1995 240sx se. I need to know if this wheel will fit because we want to run 15x10 to support 26x10.0-15 Hoosier tires.
http://www.summitracing.com/parts/SUM-561-5166PS/
http://www.summitracing.com/parts/HOO-18131/
Description of the wheels:Wheel Diameter 15 in. Wheel Width (in) 10.00 in. Backspacing (in) 5.500 in. Offset (mm) 0.00mm Wheel Material Aluminum Wheel Finish Polished Wheel Construction 1-piece Lug Nut Seat Style Conical seat - 60 degree Hub Centric No Center Bore Diameter (in) 3.268 in. Center Bore Diameter (mm) 83.00mm
Can some-one tell me if this wheels will fit on the 240SX SE 1995 ? Maybe we need to use some spacer ?
Thanks
