Planning to get the Summit Racing Fast-Five in 15”x10”, 5”x4.5” bolt circle with a 6.5” backspace. Reason with going with the wider 10” vs the 8” is that the wheel will create a flatter area for the tires when going down the track (stability).
http://www.summitracing.com/parts/SUM-5 ... /?rtype=10
Tires and size options in order of preferance will be (M&H Racemaster/Hoosier QTP/Mickey Thompson ET Drag):
1) 28”x11.5”x15” (My concern is the 28” height and 11.5” diameter rubbing)
2) 28”x10.5”x15” (Height may rub and diameter of tire may fit)
3) 26”x11.5x15” (Height will fit, but not too sure on diameter)
4) 26”x10.5x15” (This will fit from researching other setups.)
http://www.summitracing.com/parts/MNH-MHR50/?rtype=10
http://www.summitracing.com/parts/HOO-17421/?rtype=10
http://www.summitracing.com/parts/MTT-3055S/?rtype=10
here's some shot how it looks
