Drag Vids from Friday Night.
f150intally
hey guys,just thought I would post my videos from Friday night. They were taken using a stickypod camera mount. let me know what you think.
car wasn't hooking (even on drag radials) worth a crap because of the lack of track prep. they didn't put down any VHT.
best run was a 13.3 (against the 350z) and that was with only a 1.95 60 ft. the setup, atleast in the blue car, has cut 1.7s on drag radials. I know the car can go faster just not that night. everyone was plagued with traction issues.
PLEASE RIGHT CLICK AND SAVE AS
Modified by f150intally at 1:05 AM 4/2/2005
silva180sx1515
what revolutions do you typically shift at, how much boost are you running
WONit
Car: 89' 240sx Redtop
what all do you have done to your car?
mynismo
you know you are shortshifting gears by a big amount.
i always got best times holding every gear up to redline. you should be doing high 12's at worst on the t25 and dr's. you have a diff?
slow s13
Car: cars, photo, music
I think he shortshift because it keeps the car on boost cuz the t25 cant keep up at high rpm's
f150intally
1st = 75002nd = 7k-72ish3rd = 6500
f150intally
WONit wrote:what all do you have done to your car?
http://home.comcast.net/~jaywa....html
f150intally
mynismo wrote:you know you are shortshifting gears by a big amount.
Yes, i am intentionally short shifting 3rd gear. The power on the stock t25 falls off dramatically after about 6200 rpm. What times have you ran on the stock t25. I have ran multiple 13.0s in my car. I have over 50 passes in the car so I pretty much know my optimum shift points.
mynismo
hold the gears. with stock turbo i was trapping almost 107mph... real crappy 2.2 60', and a 13.4, with open diff on the stock shifter.
holdem.
do you have a lsd? 12.9's should be possible with street tires and lsd. i understand track conditions aren't optimal at this point in the season because no one takes the time to prep the track yet.
60's are usually as follows:open diff + street tires = 2.2open diff + dr's = 2.0lsd + street tires = 2.0lsd + dr's = 1.8lsd + slicks = 1.6
if you are a good driver you can even beat those. 1.8's usually equal 12.6's.
HolyShiznit
Car: Working on my car
If you dont' mind me asking. How are you doing the burn outs before each run? What is your technique? Cause I just bought BFG drag radials for my 240 but I am unsure of how to do the burn out......thanks for responding.
BTW: You will have better luck next time, good times regardless.
mynismo
yea, im wondering that too...
also, the reason you hold the gears is to stay in the power band. yes, peak power is 6k but if you are shortshifting thrid, when you go into 4th you do not go into the power band. same thing goes with 1>2 and 2>3.
Henry G
Links don't work. Can you post your mods. Impressive times.
f150intally
sorry,i didn't realize people were still responding to this thread. Ok, I fixed the link for the movie. Hosted it else where.
to address some items in this thread.. my shift points are this:
1st > 2nd : 7500rpm2nd > 3rd : 7100-7200rpm3rd > 4th : 6700-6800rpm.
MyNismo: Yes, I do have an LSD. Not being a jerk, but how many passes to do you have on the stock t25 turbo, while using LSD and drag radials? I have over 60 passes on my two s13s, both while using the stock turbo. During my experimentation through these 60 passes, I have determined that these are my optimum shiftpoints for the stock turbo. The reason you were trapping 107 was because of your crappy 60 ft time. You will learn that as your 60 ft time gets better your trap speeds go down some. higher trapspeeds but slower ETs is an indication of traction problems, specifically in the first 330 feet of the track. I have been to the track on both slicks and drag radials. As a matter of fact, I have never been on street tires because it is POINTLESS in my opinion.
If you want to learn how to launch your S13.....
then read my launch guide I wrote for the new Drag240sx.com website. This site is for drag racers only if you want to join.
Concerning the burnout, watch my video. while still in the water box, i tap the gas and on each successive tap raise the rpm till i get to about 5k. I then drop the clutch and step on the brake. Hold the brake firmly and you shouldn't have any problem doing a burnout. Look in your rear view mirror until you see white smoke. Your wasting your time doing burnouts on street tires so don't bother.
let me know if you have other questions. I encourage you to read my article.
f150intally
my mods can be located here. http://home.comcast.net/~jaywa....html
Henry G wrote: Links don't work. Can you post your mods. Impressive times.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
you need to let me know next time you come down to valdosta (cecil) to the track. we can race. i gota blacktop sr too =). what city you live iin?
Modified by getnrowdy23 at 8:22 PM 4/4/2005
tm_kickz
what size slicks do you have? Im looking into getting some for my stock se 7spoke wheels.
15x6.5
SILVIADRIFTR
Car: 1993 nissan k's silvia
I run 26X10.50 et streets and slicks on my stock alloys.
f150intally
getnrowdy23 wrote: you need to let me know next time you come down to valdosta (cecil) to the track. we can race. i gota blacktop sr too =). what city you live iin?
Tallahassee, have I seen your car out there? I got out there quite a bit.
f150intally
most of the time I run 225-50-15 drag radials. The few times I ran slicks they were 22x8x15s.
tm_kickz wrote:what size slicks do you have? Im looking into getting some for my stock se 7spoke wheels.
15x6.5
