Drag SR20 Setup???
wicked_nismo
Car: 1990 240sx, 2003 SER Spec-V Sentra
Ive had my 90 240 for way too long without the SR. I like drifting, but sometime i know i will meet the ditch or curb lol. I crave speed, so i was plannin on this setup. I got about $5,600 to spend
SR20 Red TopGT30 TurboTomei 272 CamsFront Mount Intercooler (Undecided Brand)Turbo XS Dual Stage Boost Controller (7psi 1st and 2nd, 15-20 3rd and 4th)Nismo LSDNitto 555 Radials15-20 psihoping for about 380-420 hplow 13's high 12's
Just wanted to see if its do able.....if not suggestions
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
You can run low 13's and high 12's with the stock t25...You dont need a upgraded turbo,or cams to run those time...250-260whp on a s13 will get you the times your looking for..
wicked_nismo
really? I just want 12's anything lower is just icing on the cake. i was just worried because i know the t25 tend to tapper when you run high boost. I was just going with the GT30 because it spools quick and can give high boost. But im kinda new to SR's.....i dont know what they can hold safely on stock internals. Because this is goin to be an everyday driver also.
sssrdub
Car: 1971 Datun 510
1978 Datun 510
Just get a S15 or GTir turbo.... great reaction and much better than t25 .... low 12's high 11's possible
wicked_nismo
Yeah the T28 is a good response charger. But what is the max psi on it? Cause i dont wanna max it out. Or boost spike or nothin. ofcourse on a daily basis i will only run about 5-7.
sssrdub
Car: 1971 Datun 510
1978 Datun 510
I ran mine at the drag strip at 14psi and ran a mid 12 ... max is about 18psi efficiently... I have seen some go to 20+ psi but that is beyond what its efficiency is at
drftsx
Car: 90 240sx(sr)
whats your set-up??
sssrdub
Car: 1971 Datun 510
1978 Datun 510
drftsx wrote:whats your set-up??
pretty basic...redtop sr.. s15 t28 , 3" dp, exhaust, front mount , z32 maf, 555cc tomei inj, j30 lsd and srperf tune rom tuning with wideband o2 at a dyno..
oh yeah forgot about the apex boost controller
Emperor_Tha
corba maf, gt2871r, fmic, jim wolf flash, lsd and drag radial. sounds good to me
