MeanGreenS13 »
https://forums.nicoclub.com/meangreens13-u31833.html
Tue Oct 09, 2007 4:19 am
ive been around drag racing a long time. Yes you do want coilovers for drag racing. They are a customized set of MR's that i have done up with moroso Drag Launch springs. (4kg spring rate rather than 8)
The biggest thing with a coilover is getting the car's ride height correct so it will not lift the front end off the ground (thats just a loss of ET) and the other thing is the coilovers will help you leave the line straight if you set them up properly.
im no drag racing dummy. I know a solid axle setup would be better. Cant afford that at the current moment. But 90% of the drag cars (door cars) you will see at your local track that are tubbed out with big 15" slicks, are using coilovers. its an adjustablity thing, setting the ride heigh from side to side can help the car more than you know.
as for wheels, i did 15x8 out back with 15x4 up front.
