Drag Radials on Stock S13 Steelies...
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
this is probably going to be one of the strangest questions asked in this section in a while
Anyway, my buddy had a red S13 with SR20DET and some MR coilovers on stock steelies. He ended up putting some pretty fat mickey thompson drag radials out on the back of the car... but i cannot for the life of me remember what size they were...
Im thinking they might have been 275/50/15 and thats what he thinks it was too, he had no rubbing issue other than on a hard launch if the suspension was TOO soft, it hit the top of the fender
does this seem at all possible or was it a smaller tire?
phil
yokota180sx
Car: 1997 Stagea RS4, r34 front
its possible if its on stock wheels
MeanGreenS13
i know the stock steelies are fairly heavy, but i gotta use what ive got for now... thanks, any more input is welcomed im just kinda scrounging cause it seems there isnt much info on this type of setup... they wont get put to use till my CA is fully assembled and running anyway
phil
gumby74
If the stock steelie is 6.5" wide, I don't know that putting an almost 11" wide tire would work out very well. I personally would not put a 275 on anything less than a 9" wheel.I think you would be pushing it with a 245/50 on a 15" wheel.What kind of driving/performance are you looking for?
yokota180sx
gumbyseriouslyare you like learning impaired?
Drag slick = drag racing = straight line = a big fat *** tire will work fine
MeanGreenS13
yeah man drag radials are straightline only, im gonna put a set of 5zigens on also but thats already been figured out. I just couldnt remember if i was thinking of the right size
gumby74
Let me re-phrase my last statement.Drag radials are for all out grip. Thats a given.They also rely on certain air pressures to maximize contact patch. We all in aggreance so far?Well if you are trying to run an 11" wide tire on a 6.5" wheel, you will not maximize the contact patch of such a wide tire no matter how low the air pressure is.As far as drag racing goes, you will need some slip in your set up. It is preferable to have that cushion at the cheapest/easiest to correct point: the tires. You got an extra transmission, clutch or any other driveline that will be absorbing the shock you will be generating?I stand by the 245/50 on a stock steelie. If you are going to be running 300lb/ft of torque or less. Especially if you will be driving this on the street at all.
gumby74
And yes, I am learning impaired. There is so much to learn and never will there be enough time to apply it all.
MeanGreenS13
gumby74 wrote:Let me re-phrase my last statement.Drag radials are for all out grip. Thats a given.They also rely on certain air pressures to maximize contact patch. We all in aggreance so far?Well if you are trying to run an 11" wide tire on a 6.5" wheel, you will not maximize the contact patch of such a wide tire no matter how low the air pressure is.As far as drag racing goes, you will need some slip in your set up. It is preferable to have that cushion at the cheapest/easiest to correct point: the tires. You got an extra transmission, clutch or any other driveline that will be absorbing the shock you will be generating?I stand by the 245/50 on a stock steelie. If you are going to be running 300lb/ft of torque or less. Especially if you will be driving this on the street at all.
buddy i promise you ive been drag racing longer than you.. i know you need "SLIP" my buddy steve who had his maroon hatch with STOCK SR on 14psi got a 1.6 60 foot out of the tire selection he had, leaving off a 2 step... i do not care if it breaks something, if you aint breaking parts, your not trying hard enough END OF STORY
gumby74
If your bio is correct, you are 22 years old. You have not been doing **** longer than me.
Oh by the way, Outstanding work on your '92 240. That 11.7 is pretty damn good. And lastly, don't get it twisted homey, I ain't mad atcha."We have to be good to each other, watch out for each other and take it easy. And if its easy, take it home. " The Gospel of Lizard.
MeanGreenS13
11.7 sucked honestly, it had 11.3 capability but we shattered trans 2nd run... it was 30 degrees out track had TOO mcuh grip, anywhozle, all i wanted to know was hhis setup... i would LIKE to get some Welds for my car but dont know what offset or anything id be looking at... and im not too crazy about the draglites or rodlites which seem to eb the only 2 that take 4 lug pattern like nissan has...
