drag radial for stock s14 SE wheel
Structure240sx
im lookin to get a set of drag radials on my stock wheels for when i go drag racing. i wanted a set of MT E/T streets but cant seem to find them in a size for my wheels. i found a place that can put nitto 555r's, 225/50/16, on for $130 per wheel. then i was lookin at BFgoodwrich g-forces. i have no idea what to go for. what about kumho victoracers or are they just for autocrossing? sorry for being vague and unorganized but it jsut took me about 4 hours to get my engine on its mounts and im a lil out of it. thanks
-Anthony
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Kumho Victoracers are designed for track use and will not have the same sidewall construction you need for good straight line hookup for drag racing. I would stick with a tire designed for that purpose like the BF Goodrich or other drag radial. The sidewalls are designed to flex more under hard acceleration and allow the contact patch to enlarge in front of the wheel as the tread 'bunches' up.
Structure240sx
thats what i figured. does kumho make any drag radials? and u dont carry nitto do u grant?
Grant@tirerack
No drag radials from Kumho and Nitto is not one of the lines we sell.
Structure240sx
do u have any suggestions say among:nitto 555rmicket thompson e/t streetsBFgoodwrich
Exar-Kun
Car: 2005 350Z
mickey thompson or the bfgoodrich will do better, the nitto isnt a true drag tire, its just a tire compound that gets sticky when hot, and unfortunately, when it gets too hot, it gets very, very slick.
its kind of a street/drag interbreed...better for drags and a street tire, but not nearly as nice in corners.
:)-chet
Structure240sx
yea i want the MT's but the nitto was the only one i could find so far in the size i want. any idea where to get a good seliction for MT's?
Exar-Kun
Car: 2005 350Z
summit racing :)-chet
Touring240
the nitto 555r 225/50/16 is discontinued.unless you can find a place with old stock
Structure240sx
i called the closest dealer which was in delaware and they said $129 installed for each wheel for 225/50/16. i dont doesnt look lik ill be goin with them anyway
