95_240sx wrote:how about a TS04? Those have been tested and proved on Supras
Rick
Just because a turbo works for one motor well does not mean it is a good match for another motor.
That being said, the TS04 appears to be a good match from the compressor maps I plotted. It will probably be a bit laggy, but depending on the boost level(I mapped out 1 bar(14.7 psi) it looks like the efficiency will be about 78% at least most of the time. It may start out at about 76 for a small amount of time at midrange RPM, but should be at 78% from there all the way up to redline. I mapped it for a KA with stock redline(S14).
