Drag DR-20 wheels VS 180sx Brakes
oldsilvia-s12
Car: Nissan S12-1986
I own a S12 with the front end converted to S13 suspension using 180sx component, so I have 180sx 280mm rotor brake in the front. Now I'm searching a new set of rims and wow the Drag DR-20 (Work equip 03 replica) look badass, but I'm kind of scared about caliper clearance in the front. So I was wondering if anybody on the board as fit them on his 180sx or can just check! If it's not possible, at least take a mesurement of the internal diameter about at the level the caliper will be.
I'm woried of it since I know it won't fit some scion in the front (caliper clearance issue)
D3stro
It should fit with no troubles. the calipers of the 180sx/s13 jdm on front are little bit bigger than the s13 usdm one. C'est pas comme si tu aurais mis des calipers de z32. Go for it if you like them.
livinglegend2100
they dont fit the scions cuz.... scions are gay. hella gay. especially that stupid-*** boot/box lookin one.. **** those things. sorry.
-end threadjack/rant
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
i request pictures of said S12 before i will do anything.
wynnEZ
Car: 90 240 CA POWA!
Yeah I would like to see some pictures also. Man up!
tramp_drift240
Car: 1992 240sx SE Coupe
also want pictures. i wanna see.
oldsilvia-s12
I have some pics, but most are from before the conversion. Now I'm on megan racing coilover.
a custom rc s12 I've built!
this is my stock 15" wheels brake clearance, my little finger won't fit between
that's about it!
tramp_drift240
sweeeet, i finally came back to this thread with a surprise of cool pictures.
make it lower!
i think ive got a thing for older body styles, a large majority of s14s dont really do anything for me
LOWER LOWER!
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Is that an oem lip kit arount the whole car? It looks SWEET!
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Rock J30/Q45 brakes! They'll clear 240sx 15" steelies.
oldsilvia-s12
ILoveMyRHS13 wrote:Rock J30/Q45 brakes! They'll clear 240sx 15" steelies.
So with what you just said. then my brake should easily clear those DR-20 in 15"?
@tramp_drift240:The 3rd pic is the only one taked after the drop on the megan. Now the front is LOW (the tire goes inside the fender, but since it's the stock wheels it doesn't rub). I just have to lower the rear a bit now and then I'll get a couple of recent pics. My car is so low that I needed all the plywood of the shop when I bring it to the enlignment... and even with it, the downpipe grinded the machine, idem for the rocker panel
I also got a nice camber in the front. I'll shoot more pics from sure when it will got new wheels!
@supreamS14: Yes it is a factory body kit taked from an S12 SE (VG30E model, us only). Since I live in Canada (No S12 SE were sold in canada), I've brought it from a guy on club-s12 from california!
iandrew89
Car: '89 Nissan 240sx Redtop SR
'94 Infiniti J30 Stock
'91 Infiniti Q45
nice i hope everything works out for u
pntang
Car: '93 Nissan 240SX FB White
yes...any 15" wheels w/ 20+ offset or more will clear even the z32 caliper...ofcourse the dr2 has 45+ (didn't know they have 0 offset, correct me if i'm wrong) so for the s13 caliber it'll fit fine...worse case scenario u'll need some spacers (which will better anyway)...i know this for a fact cuz me and my buddy bolted z32 caliber onto his s13 and we tried an enkie mesh w/ +40 offset and it didn't fit but the enkie mesh w/ 0 offset fit fine...and for safe measure we bolt on my ebay 15x7 w/ 0 offset and it fits too...of course its a little tyte but it rotates w/o rubbing or grinding
oldsilvia-s12
Yes the now make the 45, 38, 10 and 0 offset. All in 4X100 except for the 0 offset wich is only available in 4X114.3.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Off to wheels/brakes/suspension you go.
