drjohn »
https://forums.nicoclub.com/drjohn-u115.html
Wed Sep 04, 2002 10:38 am
Technoman, It's quit possible you have a vac. leak when cold that doesn't show up when hot. It only takes a small leak when cold to cause this type of idle. Put the fact that it happened after the 44k has me curious. You could have one injector dibbling instead of spraying. The 44k comes through the injectors and into the cylinder head ports do to the placement of the injectors in the manifold so I don't see how the 44k could affect anything other than the injectors. The 44k could have dislodged a deposit in the fuel line or rubber feed hose and may have gotten into a injector.This may account for the rich mixture.
