No that's different stuff. I think that has an octane rating of 0. DO NOT use that. if your going to go pure go pure automotive grade methanol.Doya wrote:So it's ok then? lol I wonder if i could use isopropyl alcohol![]()
Again do not do that. You will be feeding ~200 deg air into the intercooler, so the air going into your engine probably wont be below 200-300deg. That's really bad.Doya wrote:On a side note, I got started on my intercooler setup todayI'm doing a top-mount setup. I got rid of the mechanical fan and installed two 12" electric fans. The intercooler sits right in between the motor and the radiator.
The intercooler sits right under the vent on my hood, so it'll get plenty of air.RustspecS13 wrote:No that's different stuff. I think that has an octane rating of 0. DO NOT use that. if your going to go pure go pure automotive grade methanol.Doya wrote:So it's ok then? lol I wonder if i could use isopropyl alcohol![]()
The intercooler needs fresh air to feed cooler air to the engine then it takes in.
You can move the radiator back a little with custom brackets and put the intercooler where the radiator was and move the radiator back with the eletrical fans in place. I've seen that a few times and it works pretty well.
~Alex
Thanks a lot dudefabrisuzu wrote:haha i like it minus the blue lights. I have the same shocker sticker just on the other side lol. Hey man its ur car, if you like it thats all that matters. I m just shocked that ur engine held up, i know if i leave my fans off at anything other than highway speeds and punch it, the temp shoots up. im runnin 17lbs, but i have an intercooler, larger oil pan, and koyo rad. Good luck with the build, keep up the uniqueness!
I know dude lol. Thats why I've already started on the intercooler setup. It should be done by this weekend. I'll post pics of it once I'm finished. Thanks for caring thoughCA18Magic wrote:
Crazy stuff man. I'd be surprised if half the boost you produced didnt go to boost leak. Easy fix though...
1. switch your blow through maf set up and put it before your turbo compressor. (much more accurate air reading since those mafs arent configured for blow through setup)
2. Stock NA intake piping isnt made to handle boost, over time youll get a leak somewhere from that thin plastic
3. Replace your bov setup. Ghetto rigging your blow off valve with silly putty to stock ribbed piping is yet another plea for boost leak.
4. There are plenty of cheap intercooler setups that would not only increase a few hp's.. but would instill longevity and increased performance from and your turbo/motor (also knocks the # 3 down since most setups will have a bov flange ready for the bov of your choice!)
Sorry if i sounded harsh. I just care about you... and your car. No ho-mo... lol
There is no, "in the books" answer for how far its supposed to be from the turbo. But I'm sure at least 12" is far enough from the compressor wheel and inaccurate turbulent air. As for the 90 deg bend? I'm not sure. Never hear of that. But most of us have 75/90 deg bends on our s13/s14's to place our maf/intake away from the motor and close to the fender anywaysDoya wrote:One more thing. I'm going to have the MAFS come off of the compressor housing like you said, but isn't there like a certain amount of space there has to be between the MAFS and the turbo. I thought it was like 18" or something. And doesn't there have to be a 90 deg. bend in there too. In not sure lol.
