downstream o2 sensor question
eyedeekay
Car: 2006 Infiniti m35
I have a 2006 m35 and the driver side cat went bad alongside the o2 sensor, so I decided to replace both the passenger and driver side downstream o2 sensors along with the cats. However, the new sensor for the driver side is apparently faulty, its giving me a p0057 code and data recording supports this from the obdii scanner app. My question is: are the passenger and driver side downstream o2 sensors interchangeable (the blue and green plugs)? The old passenger o2 sensor apparently still works and I would rather not have to buy a new o2 sensor again :)
Ilya
I do not believe they are as if I recall, the part numbers are different. You can cross reference this by using a parts site like InfinitiPartsOnline.com or something.
Now, that doesn't also mean that different part numbers = different parts but in my experience it does. For my wife's new 2016 QX60, there are 2 sensors who share the same part number and 2 others who have different part numbers.
eyedeekay
Ilya wrote:
Mon Jun 24, 2019 6:01 am
Ok, so after long hours today I have found that the "faulty" o2 sensor indeed actually works, however the male connector harness for the driver side is somehow broken, the o2 sensor sometimes "works" and then decides to stop working :confused:. I will keep updated if I find a fix to this w/o resoldering a whole new connector
