I thought that was what we were talking about If not, disregard my post if its not in manual mode.tollboothwilley wrote:My G35 doesnt do this at all...i've never felt it shift down unless i was in manualmatic.
i always drive on manual mode also so i always use my engine break when slowing for a stop (speed permitting)... two reasons... one, save my brake pads... two, hear the rumble of the exhaust.. ... i might also add that nissan replaced my transmission three mos ago because of a faulty bearing and i haven't really notice that "lurching forward"... i did though before, on my old transmission... i'll keep an eye out for it...kmckis1029 wrote:i drive in manual mode 60% of the time and utilize downshifting to "engine brake" beofre i even hit the actual brakes.
if you look in your owners manual every gear has a max speed... and they recommend a use for each gear, and even use the term "engine braking"ACoupe wrote:What's this "braking" you all speak of?
For the most part I agree with, depending on the braking period (such as down a long hill).johnparkyourcar wrote:especially for the 5AT, i would use the brakes instead of downshifting... maybe its just me but it feels that using the engine to brake is a lot worse than using the brakes. replacing brakes would cost a lot less than replacing your transmission...
I would think by the time you put it in manual mode and then downshift it, that you would have been far better off simply standing on the brake. Since the brakes (assuming they are not completely out to lunch) have the ability of completely locking up (minus the effects of ABS) you would not recieve any benefit from engine braking except maybe in between the actions of ABS.kmckis1029 wrote:yeah you are right...but i love the great sound it makes!
plus i dont always do it... and im on the brakes a little too...
i see the g35 as a liability and i treat it that way... i keep it well maintianed... and im going to drive it til it wont start... but with the way i take care of cars... it'll be driving strong 5 yrs from now... if not longer...
if you ever have to make a sudden stop.. pop it in maual mode and down shift and brake... it saved me from this bastered that cut me off just as a light was turning red... so i my stopping distance was cut in half at an instant... when i was just going to run the yellow...
what a great car, the g35
If its annoying to you and you don't recall it doing it before, I don't see anything wrong with going to the dealer and having it checked out. Worse case.... they say they don't know. Best case, they know it or figure it out, fix it and tell you what they did and post on here informing us what the problem was and what we do to fix it.apro06g35 wrote:Thanks everyone for the responses dunno what i would do without you guys.. its still under warranty do you think it would be worth a trip to the dealership to get everything looked over, they havnt seen it yet because i only purchased the car about 2 weeks ago?
