Downshifting
TheJerseydude
Car: 1994 Ininfiti Q45
Do you downshift your Q? ive been havin a brake issue so i been downshifting alot more often. is it harmful to the car in anyway? How often do u downshift and where/when?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Generally speaking, brakes are a lot less expensive to overhaul than transmissions. Use each for the purpose for which it is designed.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you are at a lot more risk letting your brakes go bad than a transmission. If you have brake issues you need to take the car off the road and get it taken care of immediately.
Q45tech
A remanned transmission cost $3,000+, brake pads and rotors won't exceed $800.
Always abuse the system that costs the least to repair.
unknown007
Car: White 1993 Q45 (G50)
Some people i hear shift like if it was manual.I doubt it'd mess up your transmission that bad.It does help slow down though.
Q45tech
Transmission are warrantied by JATCO for 100,000 shifts, every shift you add unnecessarily shortens the life time.
Transmissions that do mostly interstate cruise operation seem to have double the life of those used in city traffic.
Life miles are all about how many shifts per mile!Each shift over life time costs roughly 3 cents* vs less than 2 cents per mile for brakes.
* based on a $3,000 transmission replacement and 100,000 mile remanned life
