It grinds going into 3 and going into 5th from neutral coasting if I don't rev match before pressing the clutch.get_up_mark wrote:just curious..whats the condition of everyones synchros? my 2nd 3rd and even 4th now are rough especially in quicker shifts. i have 80k on my trans. overall its a little notchy but not worth replacing internals at this point.
umm unless your double clutching it doesn't make one bit of difference to your syncros...and I pretty sure, or at least hope your not double clutching...syncros are matching the difference of speed between the input shaft and output(main) shafts of the transmission. Rev matching is matching the speed of the engine and wheels....so If you put the clutch in and rev match it is not spinning the input shaft/cluster shaft of the transmission up to the same speed as the engine, and the syncro still take is forced to speed up the gear on the main shaft, the counter shaft, and input shaft. only when you rev the engine with the clutch engaged (foot off the pedal) are the input/counter shafts of the transmission spun up too speed so that the syncros don't have to work.ArticDragon192 wrote:Hahaha, not to mentions the synchros will appreciate it if you rev match too.
Whoops, haha, sorry,m was thinking about double clutching. That's what i normally do to save my worn down synchros. The shifting is so smooth.Red coupe wrote:
I think one of the best aguments for heel/toe is it feel soooooo good when you get it exactly right through a mid-high rpm 2nd gear corner...
