too dangerous. there is no fail-safe with a steering by wire system. i think that is why production cars don't have them. throttle by wire you can just fail to closed throttle if any of the sensors go out. with a steering system, you can't just assume the driver wants to go straightDarius wrote:I think someone should install a drive-by-wire steering servo on an RB-swapped 240 to make room for larger down pipes. Any takers?
