Aaron_9349 »
https://forums.nicoclub.com/aaron-9349-u14669.html
Mon Aug 16, 2004 6:38 am
The SR downpipe can replace your "stock first cat to second cat" pipe. I eliminated mine with an Apexi GT Spec downpipe... except I had to weld a flange into the pipe for the senor located on my stock pipe. I don't think this sensor is present on the pre 95 models, but the exhaust pipe is the same. So, if you could get a first downpipe... I refer to it as the O2 pipe... one that can connect from your turbo, and go down to where your stock headers end (and have a bung for the O2 sensor and for the EGR valve), then you can simply pick up where the that pipe leaves off w/ the SR downpipe.
Hope this helps. I tried posting a pic of the SR downpipe side by side with the stock one, but the file size is too big. If you want I can email it.
