Downpipe on sr20det
240 Doubledrive
I have a question with the downpipe on the sr20det. Which side connects to the cat? Is it the one with 3 bolts or the one with 2?
Hijacker
Car: '92 240sx Convertible
'94 F-150
think about it for a second. there's a long portion of the pipe, so if you connected the 2 bolt flange to the turbo elbow, the DP would run into the ground. So to answer your question, the 2 bolt flange connects to the cat.
Anand
Car: 95 Nissan 240SX
YiKeS!
put down the DP... and hand your keys over to someone else...
TruboostPerformance
Hey now lets not burn him, just take a look at it while your under your car, the 3 bolt side goes to the down pipe, the two to your cat, good luck , if you need any help don't hesitate to call
