The general consensus is to use a T3/T04E 50 trim , 0.63 A/R turbo for this manifold, which will be the one I'm going to use for my application. I'll probably be getting it here with the coating and 360 thrust bearing upgrade.
Using that turbo and ETD's manifold, I was wondering if anyone in the so cal area knows a reputable welder that can weld a downpipe if I provided everything needed... the 3" downpipe would include the wastegate dump pipe, 2 o2 bungs, an egr bung, and maybe an egt bung. There will also be a flex section somewhere along the downpipe, and a 2.5" to 3" converter section right at the turbine housing.
And once a solid prototype is done, if anyone would be interested in getting in on this? Of course, I'm not going to be profiting anything from this - you'll pay the same amount I did + S/H if you're not local.
Or if anyone already has a downpipe in the works for the turbo mentioned above, I would love for you hook me up with one.
This is going into an S14, by the way.
