I just took the beast out. I was surprised how low to the ground the thing is--I guess I got used to the idea of it being up on jackstands
She looked sooo pretty against the white snow--and just to get down/up my driveway I had to spend like an hour breaking apart like 3" thick ice on my driveway.
I forgot how much I love driving that thing and how bloody fast it is-rekindled my love for a sports car. It was my first drive with the project silvia tension rods/nismo power brace and wow--the front end is a LOT stiffer--feels like you can push it a lot harder, and the steering is QUITE A BIT firmer--feels very very nice.
So the question is--does it have a full 10 psi up to 6k rpm?
And the answer, unfortunately, is no. But it's not nearly as bad as it used to be--it used to go from like 9/10 at 5k rpm to 6psi at 6k rpm. When I had just the downpipe on it stayed at 10 psi up to 6k rpm. With the new downpipes/straightpipe/rest of the exhaust/muffler all connected, it goes from 10 psi at 5k rpm to around 8.5 psi at 6k rpm--Not bad, and 2.5 psi higher than when i had the old downpipe/cat. And wow--I can say goodbye to traction in first/second gear, even with a full tank of gas--get's real squirrely in second gear. But, the boost was kinda all over the place, which I know has something to do with the fact that it's 13 degrees out here. In fifth gear it wouldn't boost as high as it would in 4th/third, and in 2nd gear it spiked to 11 at W0T.
I think it's time for a non-homemade boost controller, but I really don't have the money for a $300 digital greddy profec-b boost controller. Anyone know of a GOOD manual boost controller that I could try out that's less than $150? JWT sells one that looks really nice--it has a ceramic ball in it to bleed the pressurized air at a more precise rate. What about the Turbo xs ones?
Also, the ceramic enamel I coated my downpipe with SUCKS. Seems like a royal waste of time--it no longer looks as beautiful as it did in pics
. From the turbo all the way down to where the exhaust starts running straight it's peeling/bubbling-and I did not take it out on that hard of a run, and was only out for like 15-20 minutes. The paint's perfect on the straight pipe/rest of the exhaust. But yeah, I thought 1200 degree paint would do a little bit better than that.
I guess I'll eventually suck it up and bring it to a place to have both my turbo manifold/downpipe coated with a TRUE ceramic coating.
And when I got back and opened up the hood I discovered a pretty large leak in my alc injection system, and I have no idea where it's coming from
Nor do I have time to check it out--I have to study for mid-term exams this weekend. I hope I'll have it sorted out when my JWT ECU comes.
Later
EDIT--I completely forgot to screw in the second o2 sensor in the exhaust system--so there was just an open hole there, and the 02 sensor wasn't connected. Maybe that made it run a bit differently, although not much...
