misterQ »
https://forums.nicoclub.com/misterq-u4289.html
Sat Oct 07, 2006 10:43 am
Sounds like the timing chain blues finally got my beloved 91q. I went to start it one morning a while back, it ran for 10secs and died.I did not try to restart the engine because I was aware of the guide problem, I actually had ordrerd all the parts a couple of weeks prior. Anyway I dismantled the front engine cover and removed the valve covers. Sure enough there was not much left of original guides but the chains looked good and all the timing marks seemed to line up "Whew". I installed the new guides, tensioners etc, then did a compression test, but little or no commpression showed on the cylinders, leading me to belive I have valve damage. Any advise on this? If the engine is damaged i would like to swap out for a newer one. The car is still in great shape
