Dousan, help!
F4ucc
Car: motorsports
Hi Dousan.
I accidentally saw your post regarding Z32 brake fiting issue on Club4AG.Well, since I am also running Watanabe RS-8 15x7 wheels with offset of +27, wondering if you could confirm that my wheels will clear Z32 26 mm brake calipers?? what about 30mm calipers? are Spacers required? if so how thick the spacer is needed?
Please let me know, as I am about to purshace a set of conversion kit.
Thank you.
friskme
go to freshalloy.com... he probably posts there more often than here if its the Dousan i think you are talkin about! hope it helps
yeswepromise
or try zilvia...he is on there quite a bit
240_Keyy
Car: '90 240 Fastback
Pink Go-dzi-ra
midnight brother
Can you post the link to Dousan's club4ag post. I just did a search and couldn't find jack.
F4ucc
Car: motorsports
Copy from Zilvia, originally post by Dousan.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>my priced (hooked up)$190 FULL z32tt brake swap (including SS lines, rotors, calipers, pads etc etc)
i can get slotted/drilled/zinc plated z32tt rotors for 90 bucks. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Damn, Dousan would you find me a set of Full Swap, because I could not get anything lower than yours.
Please contact me at [email protected]
Thank you.
Stee Flo
He is on zilvia all the time. Try him there.
midnight brother
Ack need to know about the Wats because thats a wheel possibility for me also.
