Jacko3 wrote:Thanks for the info. Let time decide if this is possible for a G-35 coupe or not. I am sure someone out there is cooking up another mod idea for the g-35 Coupe. Yes, the initial cost of R&D will be high. I doubt that will be the case as people buy it.
If you wanted to take the whole top of the motor off and transplant it on a DE-motor (and use the newer ECU and probably some wiring changes and brackets) then it can be done with enough money. But for what? It's far cheaper and efficient to simply throw on a TC or SC and be done with it.
