There's some danger to double clutching a synchronized transmission if you aren't doing it right. The problem is if you mismatch the speed it still works. So you can actually put more stress on your synchronizers than normal shifting.NSR_s30 wrote: How long have you been driving a manual car?
Why risk it if its unneccessary?nametakennow wrote:If done properly, it won't cause any additional damage
nametakennow wrote:However, on downshifts it is a good idea to rev match as that will decrease the strain on the syncros, not to mention make the transition smoother.
Sarcasm mangotak wrote:Double clutching is slower to shift then conventional clutch use right? Since you have to do more actions. So how does this help you win a race? Be it drag racing or real racing like on a track with corners.
