issanni »
https://forums.nicoclub.com/issanni-u2051.html
Thu Dec 19, 2002 10:00 pm
"On the racetrack where you're operating close to the tires' limit of adhesion, a downshift without a blip (either by heel-two, or double clutch methods) can use up all the traction of the rear tires and spin the car in the straight-line braking zone. Even for a car with a synchronized transmission, a blip before clutch release is mandatory." Furthermore, "In shifting gearboxes with synchronizers, the function of the blip is to smooth out the clutch engagement after moving to the next lowest gear. Since most racing transmissions do not have synchronizers, the blip not only cushions the clutch engagement, it also allows you to synchronize the speeds of the input and output shafts."
-Carl Lopez, Skip Barber racing school instructor and author of "Going Faster, Mastering the art of race driving"-
Not saying anyone is right or wrong, but that's straight from authoritative sources. But in their own way, both K_car and themadscientist are correct in their statements. Basically those two statements I quoted are saying that for normal street driving, 'blipping' the throttle is not necassary, but it is necassary on the track. Also, I don't know where people are getting double clutching for upshifts. I mean, yea, it was mentioned in that fast and furious movie (that right there should raise the ol' BS flag), but the whole principle behind double cluthcing is to blip the throttle..therefore raising RPMs....why would you want to raise the rpms on an upshift? As in if you shift at 4000rpm, then blip the throttle, then egage the clutch at 5000rpm??? why? Double clutching is a downshifting method.
