nando »
https://forums.nicoclub.com/nando-u122696.html
Tue Nov 02, 2010 9:51 pm
ok google search... dual rear calipers
yes it is possible... a fabed or custome braket will be needed and the use of a hydro e break will prob be your best choice for drifting.
regular caliper will engage with your break pedal and the second caliper will be directly plumbed to your hydro e break.
thus keeping pads fresher with use and being able to use your pedal to slow the car while you lock up the rear tires with e break. keep in mind that your rotors will be doing more work since there will be pressure on either side of the rotor and not letting it cool as efficently. slotted or dimpled/drilled rotors are a must or your going to warp them things quick.
this is assuming its a track car for drifting. i believe that JRs mustang has a set up simmilar and i remember that millen's solstice had a somethig to that effect
as for the z32 e break set up i think it uses a drum break but i could be wrong. either way you wouldnt use that part. just the caliper so you would have to remove/bypass that set up
