Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Wed Jul 20, 2011 11:22 pm
I don't believe it would be a lock cylinder issue. The interior lock is on a separate actuating rod as the cylinder. There's a possibility that the door latch actuating rod is messed up in some way, shape, form, or fashion. I wouldn't begin to be able to tell you how you could get to it with the door stuck closed, though. Only thing I can think of is to take the handle/window switches off, and look down in the door to see if the handle is actuating the rod. If not, there's your problem. Also check to see if the interior locking mechanism is actuating its rod. PITA, I know, but it's better than tearing the interior apart.
