Door won't open from inside?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
2013 S. Right rear door suddenly won't open from inside. Works from outside. Easy fix?
macgiver
There's a "up / down " child proof slide near hinges , keeps toddlers from double-pulling handle , opening door , then getting runover on pavement - absolutely NEEDED these days :tisk:
Many would suggest seeing IF there , and IF the actual problem or not.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If the kiddie switch isn't the problem, the inside and outside handles have different cables. The handle pivots on the inside are plastic and sometimes break. Popping the door panel loose will tell you, and it's an easy fix with a new handle if that's the issue.
macgiver
Most times , as w/me I've caused that child-proof lockout while doing ' intensive ' detail wiping around the inside , bottom , & perimeter of door AT THE HINGES areas , terry cloth towel grabbed and pulled to' inside lock ' position & unnoticed mistake happens.
VStar650CL
Technical Expert
macgiver wrote:
Mon Aug 21, 2023 11:53 pm
Yep. When it happens with customers, nine times out of ten it's a complete mystery. They have no idea how or when the kiddie switch got thrown.
phmichel
Yup, that was it. Thank you guys...
VStar650CL
Technical Expert
:dblthumb:
Return to “Rogue Forum”
